While I'm adding pics, if you suspect that your secondaries are not opening fully, then what you might consider (since it costs less than $50) is to replace your vacuum canister with a Quick Fuel Adjustable one, which is what I did. No more screwing around with those springs, which I always drop and step on, and adjusting your opening rate is done by just turning a screw driver. I circled it in yellow.
