Old 09-13-2022, 06:29 PM
Hapnyny's Avatar
Hapnyny Hapnyny is offline
Hi CRG!
I’ll answers the questions above.
Hi Tommy, the car is mostly used for Track events and some times a morning drive. I belong to the BMW Club of NY.
Hi rustyrims, the 347 is a stage three from Prestige Motors, you can look them up on YouTube. 347 Stroker 500HP, they use AFR heads. They just recently built a 363 Stroker out of a 302 pushing 580HP with 7K RPM. They know how to build a motor.
Hi Chicagowil, thanks for pointing out the issues with the supercharger. I was going to go with a single 4 barrel but the air box issue is a pass.
Hi twobjshelby, the Cobra is under powered with the 289, the set up is coil overs all around with 10.5 rear tire and a 8.0 in the front. Car handles and brakes well but is about 100hp short of being a balanced vehicle.
Hi incoming, the set up is a C4 with a manual trans body and a Lokar Modified Shifter.
Everyone thanks for the feed back and I look forward to the responses.
