Thread: Low on power?
  #32 (permalink)
Old 09-16-2022, 03:31 PM
cobragene cobragene is offline
Cobra Make, Engine: Everett Morrison FE 428
Patrick I completed all of your tests and they all passed, diaphragm held and no vacuum leaks, I am going to try the shorter more restrictive air cleaner tomorrow but that doesn’t seem very likely, I read somewhere to remove the diaphragm check ball and take a very small screwdriver and tap it on the ball seat to make a slot so more air can flow, does that make sense to you? I also read you can drill out the passage to the diaphragm, but I couldn’t see a way to do that. Again thank you all for your help.
