Old 09-20-2022, 01:27 PM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
So, does 500 psi seem OK, or low for line pressure? If it's low, any ideas what could be wrong?
Argess,
I agree with Ed's answer - it seems your brake line pressure is below "standard." Here's a typical article on pressure: https://info.mpbrakes.com/faqs
If you DuckDuckGo brake line pressure this is kinda typical of the result.
It appears 750-1000 psi is a much more common number for brake line pressure. A bit higher for panic stops.
Measuring your present master cylinder's actual diameter seems like a good place to start.
Tom
