Old 10-12-2022, 10:53 AM
patrickt patrickt is offline
Originally Posted by Morris View Post
One of the first items a tech inspector at any SCCA, IMSA, or NASA will check is when you turn off the main power Switch ..does the motor stop.....if not they will not pass you to run in the event....
Uhhh, how 'bout "it does, if you also pull this other wire out over here...."
