How on Earth can you expect to control the temperature without a Thermostat???? I mean you have the coolant going through the radiator so fast it's still just as hot when it goes back in the engine. The fan you have should be sufficient. Also, make sure with that size engine that you have enough coolant in the system. But get a Thermostat first....Then come back.
