  #35 (permalink)
Old 10-28-2022, 02:04 PM
6TNCRZY 6TNCRZY is offline
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
in theory a small amount of air in the system should have no impact on ultimate pressure produced as long as the piston does not bottom out or linkage is binding. it would have an impact on feel and the amount of travel. I would check to make sure the master cylinder push rods are adjusted so that when the brakes are pushed hard the brake bias adjuster is not hitting the inside of the pedal tube, if it is touching it could limit maximum pressure.
