With that mileage, your plugs should be soaking wet with fuel when you pull them out. If that’s the case, don’t run the motor until you figure out why so much fuel is being dumped into the cylinders. Keep it up and you will wash the
oil off of the cylinders and you’ll never be able to get the rings to seat.
