Turkey Pan
I decided to reinstall the turkey pan and did not use a spacer between the pan and the carburetor, after install I noticed that the secondary linkage rest on the bottom of the pan. Has anyone had this issue? Does the pan normally have to be modified? If a spacer is needed what thickness.
I'm using a 12" oval air cleaner with 1 1/2" tall K&N air filter with the Xtreme air filter top. I had K&N custom make the air filter which was only $10 more than their stock 2" tall filter. If a spacer is needed the air top wont fit.
