11-27-2022, 04:21 PM
Cobra Make, Engine: SPF#0760
If you run over to your local auto parts store and purchase a good quality glass clip-on mirror or a replacement glass blank, you can remove the glass and disassemble your current mirror and take the SS plate (or a facsimile of it) to a local stained glass window shop and you can have them cut a blank and use a wet grinder to match the shape exactly. You must remember to modify (bend) the mirrors edge channel to match the curvature of the new glass and not over tighten the mounting clip. I also recommend also a coat of silver paint on the edge of the new glass to keep moisture from attacking the aluminizing on tge glass.
Blas
SPFWiringDiagrams@Comcast.net
