Old 11-28-2022, 11:11 AM
Cobrasnake427 Cobrasnake427 is offline
Cobra Make, Engine: ERA #492, 468ci Pond Aluminum Side Oiler
Default TKX transmission
I want to put the TKX in ERA 492 and there appear to be several options. Should I spend $1,000 on a new Quicktime bell housing or get one of the kits that comes with an adapter plate for my Lakewood bellhousing. My main concerns are to get the stick in the right place and the transmission mounts to line up properly. Also, which clutch do you recommend and should I consider switching to a hydraulic TO bearing setup?
Thanks!
