Old 12-03-2022, 12:56 PM
eschaider's Avatar
There are any number of guys on the site here that run big inch FE's and 385 series engines w/o a heat build up problem. You might want to check your tune and your cooling system.
Properly tuned with a working cooling system you should find no problem cooling your 460. If the car is running lean and/or your cooling system is compromised then you will experience a heating problem.
When it comes time to tune the engine you can take somebody's tune up tip of the week and hope for the best or you can go to a dyno and have them properly tune your 460. If you go to the dyno be sure to let the dyno operator know you are tuning for drivability not max horsepower. You might get both but the driveability and coolant temp control is what you are after not race car power. In a 2300/2400 pound car a properly tuned 460 will give you more than you care for in the performance column.
The reduced weight on the front end that you will realize with the 351 will enhance your car's handling so that is something to consider also.
