Originally Posted by renaissance man
I’m thinking what I may need to do is get a piece of plate steel maybe an eighth of an inch thick or so and drilled two holes in it that are 3.75” apart, then mount the quick jacks with their current whole spacing of 2.25” on the plate.
The attached image represents my interpretation of your idea.
Yellow = Outline of metal adapter
Green = Attachement holes at 2-1/4"
Red = Attachment when bottom hole is extended to 3-3/4"
The bottom attachment hole for the 5/16"-18 bolt
needs to be countersunk to avoid interference if the
adapter plate is positioned behind the Quick Lift bracket.
A 5/16"-18 hex key countersunk bolt will work. The bolt
head is .195" so an
1/8" would not be thick enough.
Adapter positioned in front of the Quick Lift bracket will likely
require you to hog out a relief for bottom bolt clearance (red circle).
Does this look like what you were thinking?
