  #43 (permalink)
Old 12-12-2022, 06:49 PM
eschaider's Avatar
Originally Posted by 169mph View Post
I would feel much better about dropping $3000 to $5000 on a new EFI if knew without doubt what was causing my issues. Hopefully it's an easy fix. Regardless, I still plan on replacing the EFI down the road. This would be a short-term solution. Thanks, Mike
The price of poker at The New EFI Table is not that high unless you want to make it that high. You can easily buy in for well under $2K. Click here > Well Under $2K Buy In. Then go to a salvage yard and get a 1999 - 2004 harness — maybe $100 / $200. Take the sensors with the harness. The MS3Pro PnP uses all OEM Ford sensors.
p.s. They are the only EFI supplier with a lifetime warranty <= clickable
