Originally Posted by 169mph
I’ve never installed or replaced an existing ECU harness. Is there a reason you can’t replace the existing harness connectors with the connectors from the ‘99-‘o4 harness? Thanks got h he
Your EFI system will likely come with the necessary wiring.
But let me ask you.
Assuming your problem is external when you fix it, what will a new EFI system do that the old one won't, except make the seller of the EFI hardware richer? The old one probably ain't broke. You're at sea level more or less. At constant altitude an EFI system doesn't do more than a carb...
