  #39 (permalink)
Old 12-25-2022, 06:07 PM
Chupee Chupee is offline
Cobra Make, Engine: Aurora GRX
Are you certain you were using starter fluid to try to start the car?
Did you check the connections from the coil to the distributor?
Did you check the connections both at the coil, and distributor harnesses?
Did you have spark when you got home and tried to start the car?
Have you checked the compression of all 8 cylinders?
Only take three things for the car to run:
Fuel
Spark
Compression
Time to eliminate each one.
Bill S.
Thx Bill,
I still have to ask the question from a NON-MECHANIC, that's me..
While trying to start the car there is No gas going into the carb bowls. Even with me standing on the gas pedal. What controls that simple action?
appreciated
