Old 01-16-2023, 09:25 PM
eschaider's Avatar
Originally Posted by SPF846 View Post
I have an older car (#846) and I think my headlight relay has finally died.
Why do you believe it has died?
I can see it zip tied to the back of the dash. But I haven't yet figured out how I'm going to get to it.
How is this relevant to determining if it has failed?
I've searched the forums here and have only found people saying they replaced it.
While not proof positive, this is none the less a pretty good indicator that the other owner(s) determined that their relays were unacceptable. Of course, you should not rule out the possibility the other owner(s) may have just had it in for their relay and were just looking for a reason to get rid of/replace it.
Haven't found anything about people talking about the easiest way to get to it. Makes me wonder if it is easy to get to and I'm just missing something.
A good indicator that it is not easy to do, is that it looks hard to do. Moreover, no one is suggesting an easy way to go about doing that hard job.
Any pro tips on how to get to it before I start taking stuff apart?
Can you turn on your headlights and/or did you check the fuse for the headlights?
