DanEC the bronze bushing is pressed tight into the steel outer band no movement there, Modern Drive Line states the OD being 1.85 I have two calipers and both read it is 1.87 OD. An ordinary new bronze bushing I have measures 1.85. My flywheel is mounted and my caliper won’t reach into the crank recess to get that measurement. .02” plus it being steel sounds like it may need to be pressed on?
