Borrowing a photo from David Kirkhams thread on rebuilding an original 427 suspension, this shows the steering arm and upright. Note the bend in the steering arm. The lower portion of the upright looks very similar if not the same as the leaf spring counterpart. The upper portion is different to accommodate the ball joint. Mounting points on the arm look the same as well.
