  #22 (permalink)
Old 02-03-2023, 10:25 AM
eschaider's Avatar
If you use an aftermarket ECU, the traction control is built in, usually. All you have to do is install speed sensors on the front and rear tires, set up the traction parameters and then turn it on. If you use an OEM ECU, it is there also but I am not certain what you will need to do to turn it on.
