Look at your sparkplugs, then you'll know if ou are as lean as the sniffer says. I doubt it though, it wouldn't run very well at that A:F Secondaries opening does not affect the ratio, that is determined by orafice sizing. If the motor was that lean it would be "popping" if it's way rich you'll smell it. Your headers would be glowing cherry red as well at 17:1
