Old 02-11-2023, 06:13 AM
Gpfarrell Gpfarrell is offline
Cobra Make, Engine: Superformance Mk II 289
Default Mk II Electric Fuel Pump power wire
We’ve got SPS0061 almost together. I’ve found the black/yellow wire under the fuel tank, but even with key on I have no power to it. Starting up front, there’s power to the #12 fuse and the fuse is good. When I unplug the harness under the steering column and check the pins for the 2 black/yellow wires, I’ve got no juice. Any ideas where my missing link might be? Seems to be in the 18” between the fuse box and the harness plug.
Also, what is a good key on power source for accessories? I’m adding heated seats and a couple of well-concealed Bluetooth speakers.
Thank you!
