Old 02-28-2023, 06:51 AM
Gtr_garner Gtr_garner is offline
My replies etc keep being sent to a moderator for review, can’t understand why.
The AK is a space frame chassis which uses modified jaguar front and rear suspension and differential.
https://www.aksportscars.co.uk/cobra...y-chassis-kit/
My engine started out as a Yates headed 358ci which was then stroked to be used in a pulling truck.
It never made it as dropped a lifter on idle and I bought it all for a good price.
Now it is:
9.2” Siamese Ford motorsport block
402ci
4.131 bore
3.75” Molnar crank
6” Lunati ‘signature’ I beams
Custom Ross pistons for 11:1 CR
Custom ported FTI 225cc TF High Ports
Dry sumped
Custom cam (around 260/260 mid .600’s lift @0.050)
Jesel belt drive
Will be using Efi Hardware’s billet IDA tapered ITBs. 55-53-50mm.
Mounted on a classic style cobra twin water neck intake manifold that I’ll cut up. Will mount to each bank and make a custom valley plate. Then ran by DBW.
Should give me a nice responsive 600/650hp (I hope it’ll be responsible and drivable anyway!)
