That drivers bracket looks right in those pictures. Both mounts have studs that fit into bracket holes.
If marked the bracket marked RT goes on the drivers side and the LT on the passenger.
Mount the cowl as far forward as you can and you can check the clearance.
I think I have about an inch motor to firewall.
The brackets came miss marked from CR.
There are old posts about this, a lot of them were miss marked.
The rubber mounts install opposite from how Ford installed them.
Chaney Shores Studio
