Old 06-27-2002, 10:34 PM
sfry's Avatar
sfry sfry is offline
Cobra Make, Engine: EX- Owner/Builder of a Hi-Tech & CSX4264-Southern Automotive 427 Side Oiler,Now I am sitting on the porch!!!
Send a message via AIM to sfry Send a message via Yahoo to sfry
Bit of a pickle!!
1-EBAY:Settle out of Auction and get it here..
2- I think most FE's are the same.
3- I think John it will be of a cast enviorment..
4- Remove the flywheel, Heat the flywheel with a torch. EVENLY.Start to pryoff the gear. The ring gear should come off
easily.
5-Call Mcleod or Summit.. They should have one.
6- BUY A NEW ONE!!(then I can buy the other and fix it) HA HA. No John, don't buy another. If you can get a ring gear and I can help you change it.
I did stay at a HOLIDAY INN last night..
Shannon
