Just a last thought...
have you double checked the ignition timing? Running with timing off can cause overheating.
Also, it's probably worth checking that the TDC mark on the crank damper is actually lined up correctly - the old bolt down the spark plug hole and turn the engine both ways method works fine.
HTH
Wilf
