Off the top of my head:
Engine Assembly
Engine Mounts
Transmission Assembly
Trans Mount
Transmission Fluid
Clutch Assembly / Thrown Out Bearing / Bolting
Clutch Slave Assembly / Braided Hose / Adjuster Rod Assembly / Bracket
Bell-housing / Alignment Pins / Engine Plate
Drive Shaft Assembly (custom length) & Bolting
Ignition System with Coil & Mount
Alternator & Brackets and Bolts
Brake Fluid (for Clutch)
Misc. Bolts-Washers-Nuts
Exhaust Bolting (opt. Ceramic coating)
Battery & Battery Mat & Insulating Pad
Starter
Intake Manifold Mounting Plate
Double Carb Return Springs
Carburetor & Air Cleaner & Fuel Filter(s)
Fuel Pump & Hoses (opt. Pressure Regulator)
Misc. Sizes & Lengths of Wire and Connectors
Rubber / Metal Hoses / Clamps / Water Pump
Coolant / Thermostat
Oil /
Oil Filer /
Oil Filter Block / Cooler Hoses (optional)
Emblems (optional)
Blas
