The only other door car even close is on an Excaliber- but still different.
Do you have the plastic style door card base? It would be pretty easy to have a car/RV/Boat upholstery shop redo the door cards.
I just installed my cards last week. My car is a CR1. It has the plastic base with a thin sheet of foam and the skin over that. The holes for the plastic insert style clips had never been drilled. That was the hardest part.
I also added the leather door stops that FFR sells for their Roadster.
I had my dash recovered last month- it was $500. She had to clean up the fiberglass a bit more after I removed the cover. She added a thin foam under the black covering. I think it turned out nice.
I should get the dash installed this week. Just finished the carpet today. And then the seats go in.
Thom
"Still plays in the garage"!
