Old 06-04-2023, 12:48 AM
Austria_Cobra's Avatar
Austria_Cobra Austria_Cobra is offline
Cobra Make, Engine: FFR
Originally Posted by eschaider View Post
Dry means no lubricant. No lubricant means it escaped from the bearing. The only way for it to escape is through a damaged seal. The question becomes, where is the damage, and how was it incurred? The usual method of answering these questions involves visually inspecting the bad seal. You will have that opportunity when you decide to replace the bearing.
the only seal is a rubber seal to prevent the oil from the system (clutch pedal tilton to bearing) not to flow out of the bearing, to push the bearing by pressing the pedal.
is there any other seal inside?
from Tilton:
BEARING MAKES NOISE (NEW BEARING):
• Make sure it is the clutch bearing and not the input shaft bearing.
- Does the noise stop when the pedal is depressed?
- Does it only make noise when the pedal is depressed?
• Some new bearings will make noise when skidding on initial take-up. On a new bearing, the grease is not evenly
distributed, and the seals are stiff. As the bearing breaks in, this will usually go away
is there a bearing or a seal in the flat face front of the bearing, that pushes the spring?
THX, FFR 427 MKIII.1
