Old 06-22-2023, 04:33 PM
Blackmamba Blackmamba is offline
Hi all. Thanks for the replies. I sent a post a while back after the first response with my full tech spec list when I purchased the car in 2017 but it said I had to wait for moderators to approve the post. I'll try again.
I'll respond to all the posts tomorrow morning. It's quite late here in the UK now (nearly midnight)
PRECISION MACHINED FORD 351W BLOCK
MICRO-POLISHED & DEBURRED NODULAR CRANKSHAFT
SHOT PEEN HARDENED & STRESS RELIEVED CONNECTING RODS W/ 190,00 PSI ARP BOLTS
HYPEREUTECTIC HEAVY DUTY PISTONS 9.7 TO 1 COMPRESSION
SPEED PRO PISTON RINGS
3 PIECE STEEL ROLLER STYLE TIMING CHAIN
Xtreme Energy Comp Cams Hydraulic Roller Camshaft
NEW MELLING OIL PUMP AND SCREEN
EDELBROCK RPM ALUMINUM HEADS 60cc COMBUSTION CHAMBER
STAINLESS STEEL SWIRL POLISHED INTAKE VALVES
STAINLESS STEEL SWIRL POLISHED EXHAUST VALVES
COMP CAMS MAGNUM ROLLER 1.6 RATIO ROCKERS
HARD SEATS FOR UNLEADED OR REGULAR FUEL
HEAVY DUTY 1.45 DIAMETER VALVE SPRINGS, 7 DEGREE LOCKS
NEW HEAVY DUTY CHROME MOLY PUSH RODS
NEW CHROME FRONT SUMP 5 QUART OIL PAN
ALUMINUM TIMING CHAIN COVER WITH SCALE
FORD COBRA BLACK WRINKLED ALUMINUM VALVE COVERS
HEAVY DUTY SFI APPROVED STANDARD FLYWHEEL
NEW EDELBROCK PERFORMER RPM DUAL PLANE INTAKE MANIFOLD
NEW 4 BARREL 650 CFM EDELBROCK CARBURETOR WITH ELECTRIC CHOKE
HIGH VOLTAGE ELECTRONIC PERTRONIX BILLET DISTRIBUTOR AND COIL
8 MM ACCEL SILICONE WIRES
NEW CHROME THERMOSTAT HOUSING
NEW FUEL AND WATER PUMP
CHROME DIP TUBE AND DIPSTICK
NEW BLACK WRINKLED COBRA OVAL AIR CLEANER WITH PCV VENTILATION SYSTEM
NEW FUEL LINES AND GAS FILTER
HOT RUN TESTED INCLUDES SETTING INITIAL AND FULL TIMING ADVANCE
CHROME ONE WIRE HOOK UP 100 AMP ALTERNATOR
MARCH POLISHED PULLEYS AND CHROME BRACKETS
NEW V-BELT INSTALLED AND TENSION ADJUSTED
BALANCED, BLUE PRINTED, ASSEMBLED BY ASE TECHNICIANS
