Originally Posted by Austria_Cobra
A Cat does chemical reaktions, HC is the most smelling part I know sofar and a Cat should split that.
I was told that the standard smell on exhaust gas will be significant reduced , as the cat is on working temperatur.
Unburned gasoline will not be effected.
Once again, are you smelling a lean or too rich gas smell, or raw gasoline in itself?
Do your eyes water when the car is at idle?
I ask the questions I do to narrow down exactly what you are smelling, this way we can then assist you in resolving the issue.
Bill S.
