straing behavior
I had 2 alternators (the same), one in car worked and is now dead.
I tried the good on yesterday. Start 14,0V, loading about 25A.
After an hour of ride, the voltage goes down 13,9, then 13,8, then 13,7 and then out 12V(Batterie), also now dead.
Could someone tell me exactly what this alternator needs on the pins (SILP).
Which is an input/output, which signal should be connected (voltage)
I think the alternator is running in fail safe and kills himself after time.
2W check bulb works fine (L)
clock wise (from front) rotation
8242N
HTML Code:
Chevrolet Camaro 1998-2002 5.7L Alternator
Replaces:
Bosch AL8723X
Delco 10464070, 10464402, 10464407, 10480308, 10480342, 10480343, 321-1418, 321-1746, 321-1751, 334-2486, RM1277
Denso 210-5164
Wilson 90-01-4319, 90-01-4364
HELLA 737858001
ACECA-8167-5 CA81675
BOSCH 0 986 CN0 627 0986CN0627
BOSCH F 042 300 140 F042300140
BOSCH 0 986 UN0 627 0986UN0627
BOSCH 0 986 CR0 627 0986CR0627
BOSCH 0 986 UR0 627 0986UR0627
BOSCH (USA)AL8706N AL8706N
BOSCH (USA)AL8710X AL8710X
BOUSAL8706X AL8706X
BOWERSBAO3087 BAO3087
CARGO111712 111712
CEVAM8206 8206
DELCO REMY 10464407 10464407
DELCO REMY 10480168 10480168
DELCO REMY 10462651 10462651
DELCO REMY 3211108 3211108
DELCO REMY 10480198 10480198
DELCO REMY 10463652 10463652
DELCO REMY 10480308 10480308
DELCO REMY 10463940 10463940
DELCO REMY 10480388 10480388
DELCO REMY 10480167 10480167
DELCO REMY DRZ0196 DRZ0196
DELCO REMY 3211107 3211107
DELCO REMY 10480168Y 10480168Y
DELCO REMY 10463651 10463651
DELCO REMY 3211438 3211438
DELCO REMY 10480251A 10480251A
DELCO REMY 10463690 10463690
DELCO REMY 10480343 10480343
DRI528.131.1002 5281311002
DRI528.168.1052 5281681052
DRI528.162.1002 5281621002
ELECTROLOGALT2606SA ALT2606SA
ELECTROLOGALT2654SA ALT2654SA
ELSTOCK28-3584 283584
ELSTOCK28-7897 287897
ELSTOCK28-4953 284953
EUROTEC12090142 12090142
EUROTEC12090141 12090141
HC-PARTSUA1538IR UA1538IR
HELLA8EL737858001 8EL737858001
ISUZU8104636510 8104636510
LESTER8206-5 82065LESTER8227-5 82275
LESTER8227 8227
LUCASLRA02835 LRA02835
LUCASLRA01781 LRA01781
LUCASLRA04288 LRA04288
PIC240-6175 2406175
PIC240-6174 2406174
UNIPOINTALT-1402 ALT1402
WAI1-1995-22DR 1199522DR
WAI20-1150-11 20115011
WAI1-1995-21DR 1199521DR
WAI1-1995-21DR-2 1199521DR2
WAI1-2155-21DR 1215521DR
WAI20-1150-10 20115010
WAI1-1995-21DR-1 1199521DR1
WILSON90-01-4246N 90014246N
WILSON90-01-4246 90014246
WOOD-UKALT1402 ALT1402
Delco Type CS130D Series Alternator On Chevrolet Camaro and Pontiac Firebird
Erstausrüstung / alternative Artikelnummern: 10464070, 10464407
Used On:
Chevrolet CAMARO 5.7L(350) V 1998, 1999, 2000, 2001, 2002
Chevrolet Camaro 5700cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
Chevrolet Camaro 5736cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
Chevrolet Camaro Z28 5700cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
Pontiac FIREBIRD 5.7L(350) V 1998, 1999, 2000, 2001, 2002
Pontiac Firebird 5700cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
Pontiac Firebird 5733cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
Pontiac Firebird Formula 5700cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
Pontiac Firebird Trans Am 5700cc, 5.7L/350CI V8 1998, 1999, 2000, 2001, 2002
