thermostat
Hi,
The temp should not rise to boiling! You should be able to drive with no fan on at 185 to 195*, put fan on when you slow down. I would replace the thermostat with a 180* one and burp all the air out of system. As for the fan, turn on fan and put a kleenex in front of rad and see if the fan is pulling air through rad or if they wired it reverse. try a 40 amp fuse as the amperage will spike when turned on.
Perry
PS; if the fan is blowing air forward instead of through rad the fan motor will labor in the wind and cause higher amperage draw and blow the fuse.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
