So I’m in the process of re-wiring my CR and I’m thinking there is likely no way to remove the dashboard without removing the body based on what I see. See YT video. If that’s the case, I will likely use my rotary tool to cut the bolts and hope that provides enough wiggle room to remove dash. Has anyone else had to remove the dash after assembly is complete?
https://youtu.be/aCQ1XSedq5s
