Old 07-10-2023, 10:52 AM
eschaider's Avatar
Good point, Tom!
From my own SPF brake research, I have discovered they do not use rotors larger than 12 inches in diameter with the 15-inch wheels on their cars. While I suspect you might be able to fit a bit more rotor in a 15-inch rim, I am not persuaded it is worth the effort. A step up to a larger diameter rim is the shorter, smarter braking solution — and that opens up a whole new vista in tires ...
