Originally Posted by Ozzie Goat
What SPAL did you go with ?
Did you have to drop the radiator ??
Roy
Hey Roy...the fan I got was a SPAL High Performance Fan. Part number - 30102113. Bought through JEGS. Just type the part number in the search box. With regards to removing the radiator - no sir...I did not have to. You will have to remove the two bolts at the bottom of the black plastic shroud to get to the bolts that hold down the fan clamps. Once those are removed, the fan should slide right out.
It helps if you have a beautiful assistant...which I do! If you need pics, let me know.
Tim
