Thread: Remote Oil Line
Old 07-16-2023, 10:48 AM
Davidless Davidless is offline
Great info, now I’m wondering what is the minimum flow rate (gpm) a high performance 427 needs.
My problem is since I’m using fords high performance oil pan (came with the long block) the knuckle heads put the dip stick fitting right under where the fuel pump goes. For me to clear the tube still using the remote oil adapter, I’ll need 1/2” pipe 90 elbow.
So rather than loosing all the flow with a 90, I’m using two street 45’s to give me a greater bend, then I’ll use a 12an male flare x 1/2 male ntp adapter going into the 45 deg end. I don’t want to remove the oil pan and weld on an oil pan fitting nor do I want to spend 1000 bucks on a new pan.
For what these oil pans cost why can’t they put dip stick fittings on both sides.
Very frustrating, luckily Amazon has free returns on fittings, lol
David
