I also had an issue with the voltage regulator when I tried installing the original style voltage regulator and I wound up switching to a solid state voltage regulator that looked similar. If you need the wiring diagram I can email you the manual and my wiring notes.
My dash charge indicator light goes out when it is properly charging.
mvanhorn8893@gmail.com
Mike
