Old 07-27-2023, 05:30 PM
Davidless Davidless is offline
Default Quicktime 6060 bellhousing Reducer Bushing Needed?
Hi All
For the life of me I can't seem to find this info,
I'm indicating my Quicktime bellhousing but not sure if I need to use the reducer bushing for a tremic TKX trans. The OD of the trans flange is not listed anywhere.
Also my Ford 351W long block came with an installed pilot bearing, anyone know what the bearing ID should be to fit the TKX shaft? Don't want to bolt on my flywheel if I have to change the bearing.
Thanks
David
