Originally Posted by eschaider
Not true!
You use a collet-style dowel pin puller. They are available in the hammer slide variety and also in an in-line style that also grabs the pin OD, just like the hammer slide variety but uses a progressive wrenching approach to removal instead of the hammer slide impact approach.
These types of tools are not inexpensive. You will end up somewhere north of $150 and south of $200 unless you can find one at a tool rental — which I sort of doubt.
You will find internet search engines quite helpful as you begin your search for the removal tool you like best.
Thanks but how will the collar grab onto a smooth hardened dowel surface?
I can make a puller for nothing spent but some time.
