Update as the rear rotors were repaired. I ordered a pair of Ford SuperCoupe rear brake rotors on line. Of cousre only 1 shows up and the other was on back order indefinitely. Who stocks one brake rotor? For 20 bucks I just kept. Figured machine the other good one to match or find another t-bird rotor. We found another but ran into another issue. It matched the existing roto,r but the bolt pattern was off. The ones I believe to be original were redrilled. Anyone else found this? Or we they repaced with only 2500 miles. Pads wer said to be replaced for squealing. Used the old for a pattern and easily done. Car is running good, but I may upgrade the entire system down the road. S
2003 SPF 351W/427 stroker with port fuel injection. Royal Blue and Polished 17's.
