Old 08-01-2023, 01:30 PM
eschaider's Avatar
A Superior Strategy!
Just think of all the time and money that can be saved! Besides, when you support your local ACE hardware with your fastener purchases, you help provide jobs in the local neighborhood ... I think they might even have JB Weld! Don't forget to cut off the bolt heads before JB Welding them to the side of the crankcase.
Remember, JB Weld gives you the strength and precision to get it done right the first time (everytime?), creating a permanent bond on metal, plastic, and wood. (I would not recommend a plastic or wooden block). You can add a static mixer for a precise, no-mess-on-target application. Once cured, it can be milled, drilled, and filled!! — This has to be the proverbial "Screaming Hot Set Up!"
Worst case scenario, your local Home Depot has Gorilla Glue if you can't find JB Weld!
