Old 08-01-2023, 03:03 PM
CCXCanuck's Avatar
CCXCanuck CCXCanuck is offline
Cobra Make, Engine: CCX 3651 w/ 428 FE
Yes, you are correct about the location of the horn. Right side mounted slightly ahead of the tire. The wire should be coming out of the main harness just ahead of that. If you need a pic of mine, let me know.
No warning flashers on mine, but the headlight high beam is a button close to the driver door. As for a turn signal, I've got a lever off the steering column, so I cannot help you there.
