Radiator Difference
I am trying to get the water temp down to under 200 in this
Texas heat. I have Mr Gasket thermostat 180 with a spacer that I had machine open another 1|8 larger. I have a elderbrock water pump and march 1910 pulleys which help increase water flow. I have the hd ERA spal fan. The only difference is I have a standard radiator and no radiator stroud . With that being said what is the difference between standard and the hd radiator ?
The car run about 220 to 230 in a short distance before shut it off. This is a new build. I have only 55 miles on the engine.
