New engine I'd bet running lean. The typical fluidyne size radiator is more than adequate. If you have an oil cooler you're over cooled and will likely have trouble getting to a proper operating temp. If your water pump is pumping (is it running backwards?) Then look to tune
Tony
CSX4005LA
