Old 08-06-2023, 08:04 AM
1795's Avatar
1795 1795 is offline
The Harrison tank is how you fill the cooling system. You should not run it dry, as you risk getting air in the system as coolant constantly cycles through it. You should run it about 1/2 full. If there is significant coolant expansion there is a fitting below the cap that is where you connect a small hose to feed a catch can that you can place inside the fender of the passenger side.
Jim
