Old 08-10-2023, 03:00 AM
gcarm gcarm is offline
Cobra Make, Engine: G-Force with LS1
Default Under Bonnet/Hood Heat Insulation
Hi,
I need to insulate the underside of my bonnet/hood from heat coming off the engine. I have some leftover sound deadener that I used under the carpet in the cabin.
Will it work as heat insulation? (its 10mm thick foam rubber but it doesn't have the aluminium foil top layer).
Or should I invest in some proper heat insulation ? If so, any recommendations?
Greg
