OK, 12 gauge wire running to the powered side of the #1 fuse. That's exactly how I have mine. If putting a voltmeter on your battery shows you're getting about 14.5 volts when revving to 2000 RPM then you're definitely charging. If your ammeter shows you're not charging then either the ammeter is not working right or current is not flowing properly in that wire in that direction.
