Old 08-27-2023, 08:51 AM
Tommy's Avatar
Tommy Tommy is offline
I have three comments. First, if your engine is high strung (i.e. doesn't like low RPM like mine) I don't think you'll like the 0.68 gear very much. Second, the jump from 4th to 5th with 0.68 means you've got to be carrying a pretty high RPM in 4th to keep from lugging the engine after the shift. Last, unless you plan to do some track days where you'll be exceeding 90 MPH, the 0.81 should be sufficient. Even if you do plan to do track days you may want to go with the 0.81. If you shift from 4th to 5th at 6000 RPM with a 0.68 gear, your next RPM at that speed will be about 4,000 RPM. That may be so low in your horsepower curve that you can't accelerate much faster. A 0.81 gear will put your RPM after the shift at about 4700 RPM in a stronger part of the horsepower curve.
Tommy
Previously owned EM Cobra
