Old 09-02-2023, 09:28 PM
cycleguy55's Avatar
Originally Posted by cobragene View Post
I have the largest single booster that will fit, a 6.6” from a Subaru justy, 11” vac at idle and over 20” in vac canister after accelerating and decelerating so I am max out there. Thanks for the advice.
Good luck in sorting out your brakes and getting what you want.
I had some issues with the brakes in my West Coast Cobra, which obviously has a very different setup that you do, albeit it also has a Mustang II front suspension. I'm now running an 8" dual diaphragm booster, Wilwood remote tandem master cylinder, 4-piston Wilwood Dynalite Pro calipers up front and so-called 'large GM' calipers in the rear. Awesome stoppers!
This was a fairly significant investment but the brakes are night and day compared to the old brakes and well worth it, IMO. As a friend said, don't skimp on brakes or steering.
Brian
